TwinTurbo.NET: Nissan 300ZX forum - Re: Air in Brake Master Cylinder
Subject Re: Air in Brake Master Cylinder
Posted by canyoncarver on April 21, 2010 at 6:50 AM
  This message has been viewed 65 times.
In Reply To Air in Brake Master Cylinder posted by ZX-infinity (Dallas) on April 19, 2010 at 02:06 PM
Message If you've performed a thorough system bleed and still experiencing a soft pedal, I'd look elsewhere. When was the last time the pads were changed and the rotors were turned or replaced?
Worn rotors, either from runout or taper, will push the pads back into the calipers when the brake pedal is not being pressed. Then when the pedal is pressed, the pads have to travel farther before clamping on the rotor, causing a spungy feel.
